When I try to use 2-D drawing connector blocks when flattening an electrical route, I get the following error:
"No drawing connector block files have been found for the following components:
<part1>
<part2>
To generate connector blocks, use the Routing Component Wizard, found in Routing Tools."
I did use the routing component wizard to create connector blocks. The names match (part1.sldprt and part1-hblock.slddrw). The part and the connector block are in the same directory (X:\data\design library\routing\electrical where X: is a networked drive). I also copied the connector block drawings to X:\data\design library\routing\electrical\harnessing\packages just in case.
Why do I get this error?
Hi Ken,
Can you tell me which release you are using. I don't recall seeing any other reports of this problem, It may be network related but to be honest I doubt it. Could you please post the files in question so I can give them to QA for testing.
Andy
