Surface Boundary Issue
Question asked by Jason Aspinall on Aug 24, 2009
Latest reply on Aug 25, 2009 by Jason Aspinall
Following on from a question I raised the other day, I thought I'd solved the problem, but sadly not.  The attached part shows the boundary surface, with two additional surface fills currently surpressed.  The issue I have is that the boundary surface command appears to be creating an additional segment i my model I do not require.  Because it's there, I believe it's causing later problems when I come to splitting the model into two new files, to shell out (typical 2.5mm wall).
Ideally I would like to shell the model before splitting it.
Can anyone see why Solidworks is creating this segment? (Annotated in the model) If so, how can I remove it?
