Howdy
I have built a few models which I have populated with fastners from the toolbox which is setup locally on my machine, however when I open the assemblies on a different machine it always complains about not being able to find the fastners?
Whats the go?
From the help file
Multi-user Toolbox from Standalone
To create a multi-user environment from existing standalone installations:
Identify the computer that has used SolidWorks Toolbox most extensively.
Move the entire SolidWorks Toolbox parts directory (for example, C:\Program Files\Common Files\SolidWorks Data) from the user's computer to a shared location.
Right-click the shared SolidWorks Toolbox folder, select Properties, Sharing tab, and set to Share this folder.
Right-click the browser folder, and in Properties, General tab, set the browser folder and its subfolders to Read-only.
In SolidWorks, click Toolbox, Configure.
On the Settings tab, select, Create Configurations.
A configuration is added to a master part file each time someone uses a new size of a particular fastener.
Set other options for Content, Settings, Properties, and Smart Fasteners as needed.
Click Close.
Continue with Adding a Toolbox Seat.
