Has anyone run into this error message during a non linear analysis?
Error Msg. “Bolt Connector source surface not defined”
The bolt connector is used to connect multiple parts together. I did check the connector to make sure it’s defined properly and it look ok. I ran it through tech support also and they haven yet got back to me.
Hi Poovaiah,
Surprising. I should be able to look into this if you could provide more details such as Simulation release, part models (solid, sheetmetal, surface, weldments) that are bolted etc.
Regards,
SP
