CSWP Simulation Exams goes further than SolidWorks Simulation (STANDARD). It gets questions from FEA and theory to SolidWorks Simulation Advanced. See bellow the info about this certification:
CSWSP-FEA
The Certified SolidWorks Professional Simulation Specialist exam is designed to test an individual’s complete understanding of Simulation tools inside SolidWorks. Candidates who successfully pass this certification exam have demonstrated the ability to set up, run, and examine the results of various types of Simulation scenarios. They also have demonstrated the ability to interpret the various results available to them in SolidWorks Simulation.
Recommended Training Courses: SolidWorks Simulation
Exam Length: 2 hours
Minimum Passing grade: 70%
All candidates receive electronic certifcates, business card logos and personal listing on CSWP directory when they pass.
Exam features hand calculations in the following areas:
Free body diagrams - Resolving Reaction force and moments
Basic stress and strain calculations
Shear stress, Axial stress
Lateral strain, Axial strain
Calculating material properties
Elastic modulus
Poisson's ratio
Exam features hands-on challenges in many of these areas:
Geometry
Defeaturing
Idealization
Clean up (Ex: suppressing cosmetic features)
Material
Understanding ductile and brittle materials
Understanding material failure theories
Creating and modifying material properties
Meshing
Draft/High quality solid mesh
Application of mesh controls on areas of interest
Contacts
Simulating interactions between parts of an assembly
Modeling contacts based on loading type (Bending, Axial, shear)
Restraints
Fixed - Easy to use. Ramifications if any?
Using Symmetry to reduce model size
Using Symmetry to constrain rigid body motions
Bolt connectors - simplify assembly analysis
Loads
Force loading with respect to reference plane
Load distribution based on selecting one or more geometry in same selection set
CSWSP-FEA
Best regards,
Eduardo Camargo
