I'm trying to change the visibility of a body for many configurations in a part. Is there a good way to do this? I thought of Design Tables, but I don't think there's a way to do that. The only way currently is to change to each configuration, hide, repeat. Then, when I create a new config, it unhides the body again.
Suggestions?
Craig S.
Force Design, Inc.
Depending on your application & circumstances, it will work to change your part model to an assembly and then recreate the related features as separate parts brought in and mated or combined into the newly converted assembly. Each component can be configured for the configuration set up in the assembly parent.
