Thank very much for the reply.
My computer has SW 2008 now, so I cannot open your file. Is it possible to send the file again as 2008 format? I suppose CosmosMotion in SW2008 has the same capability for path mate as 2009.
Than you.
Than you.
The problem is that I do the model in SW 2009 and SW is not compatible between versions, so I can not open it either with SW 2008.
I have the SW 2008 full version (including Cosmos Advanced Professional) so if you post a copy of your model I see if I can fix it and post it back for you.
Also I can try to recreate my models in 2008 but will be next week-end, since I have tons of work to do.
Hi Mauricio,
Thank you for your help. I do not want to take much of your time.
I am sending a very simple assembly in SW2008 format in which I cannot make the object to follow the path in CosmosMotion analysis (you will see that I have tried it).
Hi Mauricio,
I open your model and see what you try to do.
The first problem is that in the SW 2008 version, path mates are not supported by COSMOSMotion. Other types of mates, however, may be used to achieve the same result, although this will depend on the model. Typically, a tangent, cam, or coincident mate might be a good choice. In SW 2009 the Path Mate in the model is transfered to the Motion Analysis and work perfectly, however since you do not have 2009 I created a model using a plane (which can be inclined or placed horizontal, by changing the angle value on the plane feature) and an object, the plane have a physical path and the object have two path followers (this is one of the ways to do this model in SW 2008, since the path mate do not work). The attached ZIP file contain the assembly, open it and go directly to the "Motion - 01" analysis, then run the analysis and you will see the result. After that, take a look at how the model is build.
If you want to model the movement of a car over a plane, following a path, it will require to do an object with wheels and apply a motor to one of the weels, as well as to model a steering mechanism, that will follow the path. In SW 2009 this can be done by creating a path mate between the control point of the steering mechanism and a geometric path (a sketch), however on SW 2008 this will require a physical path (either a cut on the plane or a extrussion, acting as a rail).
When doing the model you need for the analysis, you must define the real properties for the contact between the object and the plane, including friction, damping, etc. (if you what to obtain actual results). On the attached model, notice that I use "standard" contact parameters, also teke a look on how the "force" is defined.
If you can, will be better to update to SW 2009 sp 4.0 (which is available) since in SW 2008 (the first version where the start changing COSMOS into SW Simulation) the application have a lot of problems.
Hope the attached will help you.
I attached a couple of zip files with simple assembly examples of an object moving over a plane (constrained on a path) and a ball moving on a path, both use gravity on an incline plane, however yo can place the plane horizontal (by changing the angle dimension on the Plane1 and apply a force to the object. Maybe this is what you are looking for.
