Hi Krk,
Regarding the route showing transparent after exiting the route. This shows that you have a covering. We actually show the covering as transparent so that you can also see the actual route underneath. I guess we should make this optional.
Regarding the other issues you raised, I haven't seen eitehr of these issues before. I'll have to investigate.
Cheers
Development Manager - Routed systems.
Cheers
Then I choose ok and exit the harness, it still shows transparent. What is going on? Shouldn't it show solid?? When should I add the covering to the harness? After entering the edit route command, or outside of that command??
