PDF export in solidworks (How to choose certain sheets to export)
Question asked by Lance Siefken on Jul 31, 2009
Latest reply on Aug 10, 2009 by Lance Siefken
I am trying to export solidworks drawings as pdfs and have the ability as long as I export the drawing and all the sheets.
I would like the ability to only export certain sheets, by choosing the sheets from a listbox in the property manager.
The sheets show up in the list but only on loading of the add-in after that they won't refresh.  Here's the code
swModel = SwApp.ActiveDoc
swExportData = SwApp.GetExportFileData(1)
swCusPropMgr = swModel.Extension.CustomPropertyManager(
swDraw = swModel
vSheetNames = swDraw.GetSheetNames()
If swModel Is Nothing Then
MsgBox(
"No current document", MsgBoxStyle.Critical)
Exit Sub
If swModel.GetType <> 3 Then
MsgBox(
"Drawings only please!", MsgBoxStyle.Critical)
Exit Sub
swModelDocExt = swModel.Extension
filename = swModel.GetPathName
If filename = "" Then
MsgBox(
"Please save the file first and try again", MsgBoxStyle.Critical)
Exit Sub
'Get filename from path
path = InStrRev(filename,
fullpath = Len(filename)
trimpath = fullpath - path
filename = Microsoft.VisualBasic.Right(filename, trimpath)
filename = UCase(Microsoft.VisualBasic.Left(filename, Len(filename) - 7))
If Res = vbYes Then
Exit Sub
'Get Revision
Dim retVal As Object
retVal = swCusPropMgr.Get3(
"Revision", False, rev, trueRev)
If rev = "" Then
rev =
'Set PDF options
SwApp.SetUserPreferenceToggle(323, False)
SwApp.SetUserPreferenceToggle(325, False)
SwApp.SetUserPreferenceToggle(326, False)
SwApp.SetUserPreferenceToggle(327, True)
SwApp.SetUserPreferenceToggle(324, True)
'Create file
Dim boolstatus As Boolean
boolstatus = swExportData.SetSheets(1, 1)
boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
If boolstatus Then
MsgBox(FinalMessage, MsgBoxStyle.Information,
"Success!")
Else
MsgBox(
"Save as PDF failed, Error code:" & lErrors)
end if
