I was given the wrong project number to start with and now it has changed. I can re-name the description under projects tab. In the field "Project Information there is Project and Description then Parent. If I change the description it shows correctly in the Vault but in the Project box in the Vault Admin it is still the old number.
Does anyone know how to do this? It will be a problem when the next project comes up.
Thanks.
You can't rename the parent project, but you can give it a new description.
