hello,
i have created a simple channel in sheet metal. i then made a (thrugh all) hole with the hole wizard that goes from one side of the channel to the other. so now i have 2 holes in my model. But when i dimension my flat pattern in a drawing (using hole call out) it doesnt count the hole on the other side of the channel. Am i doing something wrong?
If you want two callouts, you'll have to make two different holes.
If you want the holes to line up after bending, you will have to drill the holes after bending, which means only one hole.
If you don't care and they really are two different holes, model them as such.
