I have a flatten route that doesn't show a coax cable. It will move the connector as well as all the other connectors in the harness. It wil flatten all of the wires, but will not show the coax one. When I edit flattened route, it shows the lines for the cable, I can drag the lines anywhere, but when I save it the coax line doesn't show. Anyone else having this issue?
Hi Kirk,
Could you email me the assembly (use Pack & go so I get all the library parts too), so I can investigate. If it's too large (>10Mb) let me know I'll ask Tech support to send you an ftp link that you can use. I'd like to get to the bottom of this.
The addition of a spline should have no affect, Is the spline in the segment that is disappearing? CPoint direction also should not make any difference.
Email is swrouting@solidworks.com.
Andy
I could find one SPR 514256 reporting similar issue.
May be you are seeing same issue. Are you using Multi-pin connectors?
