I was working in a small assemly when my putor locked up. When I finally restarted and opened my assembly the design tree showed my parts but the assembly on the screen was blank. I tried Cntrl Q, Refresh, opened the parts. Suppressed and un supressed. I did try to make a drawing sheet and it shows the assembly. But, when I go to the assembly file it shows nothing. What is wrong?
Have you tried to hide the parts in the assembly and then show the parts?
Are they loaded light weight?
All the parts are full of features?
I have seen parts that would loose the features, when a crash happned or if you just closed out the assembly.
You said that this was a small assembly, and your computer locked up?
It is not a feature intensive parts in it like showing a pice of expanded metal?
Have you checked out the v-card to make sure that it is up to par with the version of SolidWorks that your running. That will sometimes cause the reason for the computer to lock up........
