Task scheduler and registry editing
Discussion created by Guest on May 2, 2006
This is due to your security setting. When Taskscheduler is about to run, it needs to backup your current solidworks registry and install its version of solidworks regeistry. When TaskScheduler is about to finish, it will revert the registry settings. This is to make sure that TaskScheduler is running in a known enviornment.
To fix the problem you are having, you can change your security settings.
