I keep getting this error message when trying to show a chart in certain studies. Once I start getting the error, it won't go away for that study. Sometimes if I delete the study and start over it fixes the problem. I'd like to know what the root cause is so I can avoid this in the future. The results (CWR) file is present and of decent size. I'm using SolidWorks 2009 SP3. Thanks for any insight.
This error message comes due to the results are not available for plotting. This will happen while you copied the files in another folder, but you did not copy the results file. sometimes this error messages will appear in the nonlinear/ dynamic analysis i.e. if you run the nonlinear analysis with different time setup conditions, you plotted the results, again if you run the same analysis with different time setup conditions, if you are plotting the previous results means the above error messages appears, for avoiding this we need define the new plot.
