Hello
I have few questions regarding EPDM, could be easy to answer.
1- how can I map datacard variables to DWG custome property / how to view the blocks, variables inside the DWG files?
2- is there anyway to know files blocks or variables which we can use inside the Card editor (DWG, sldprt, sldasm....etc)?
3- whenever I drag-drop files into the vault the files are automatically added and checked-out, how can I disable that feature, to let it work in this way (drag-drop files ---> add to the vault ----> check-out?
4- when I add files to the vault, I see the creation date inside the file datacard is the current date, but whenever I view the file properties in windows explorer I find "creation date" and its different than the current date, how can I view the real creation date of the file in PDM datacard, what attribute shall I use...?
Regards
Hi Mike -
Some feedback:
Refer to the Administration Guide (look under Variables > Variable Mapping > Variable Mapping - AutoCAD Files)
Not sure what you mean here?
There is no way to disable this....
Not sure exactly what you are asking here...
Regards,
Joy
