I have a flat pattern where I have bend lines, but no bend line notes. I have checked the view properties and the option to display bend line notes is not checked and is grayed out so that I cannot change - any ideas?
Robert
Robert
I have had this seemingly happen to me too. But, when i've zoomed out the bend line notes are actually there but out in space not within the drawing borders and I've just dragged them back to their proper location. Possibly your problem, also? Not sure why that happens, I have also noticed that sometimes it happens if you rescale that flat pattern.
-Tim
I have just read this post and some others and It may be far too late for you now but I had the exact same problem.
I had a model with several configurations and used a design table to create the derived flat pattern config. When I inserted this config in the drawing no bend lines showed up. I check all the settings, (doc props etc)
The solution was to RMB the drawing view and change the orientation view to flat pattern and hey presto!
do you have the option on in tools, options, doc properties? (or is that the option that is grayed out?)
