I would like to be able to process all files in a folder and have them converted to dwg
i recorded this macro but was not sure how to get it to automatically process all the files
any help would be appricated
dim ext as SwConst.swDocumentTypes_e
dim mydir as System.IO.DirectoryInfo
mydir =new System.IO.DirectoryInfo(Path)
for each System.IO.FileInfo myFile in myDir.GetFiles("*.Sld*",IO.SearchOption.[TopDirectoryOnly]/[All]Directory)
if(myfile.Extension.toUppder()=".SLDPRT) then
ext=SwConst.swDocumentTypes_e.swDocPART
else
ext=SwConst.swDocumentTypes_e.swDocASSEMBLY
end if
part.openDoc(myFile.FullName,ext)
part.saveAs(NewFilename.dwg)
part.close()
next
''Wote off the top of my head but that is about it
using SolidWorks.Interop.sldworks;
using SolidWorks.Interop.swconst;
using System;
using System.IO;
using System.Windows.Forms;
namespace ToDWG.csproj
public partial class SolidWorksMacro
public SldWorks swApp;
public IModelDoc2 swModel;
public string folder;
public string[] files;
public string result;
public void Main()
FolderBrowserDialog fb = new FolderBrowserDialog();
if (fb.ShowDialog() == DialogResult.OK)
folder = fb.SelectedPath;
files = Directory.GetFiles(folder);
int errors = 0, warnings = 0;
foreach (string file in files)
FileInfo fi = new FileInfo(file);
if (fi.Extension.ToLower() == ".sldasm")
//Do Nothing
if (fi.Extension.ToLower() == ".sldprt")
//Do Nothing
if (fi.Extension.ToLower() == ".slddrw")
swModel = swApp.OpenDoc6(file, (int)swDocumentTypes_e.swDocDRAWING, (int)swOpenDocOptions_e.swOpenDocOptions_Silent, "", ref errors, ref warnings);
swModel.Extension.SaveAs(fi.Name.Remove(fi.Name.LastIndexOf(".")) + ".DWG", (int)swSaveAsVersion_e.swSaveAsCurrentVersion, (int)swSaveAsOptions_e.swSaveAsOptions_Silent, null, ref errors, ref warnings);
result += file + "\n";
swApp.QuitDoc(file);
swApp.SendMsgToUser2("Files saved to DWG: \n" + result, (int)swMessageBoxIcon_e.swMbInformation, 0);
Above code will open every drawing in a folder and save it to DWG..
This should Work I tested it
Dim Part As SldWorks.ModelDoc2
Dim boolstatus As Boolean
dim path as String
Dim file As String
path ="C:\Documents and Settings\BakerRob.PTT_LAN\My Documents\MGQ\"
file = dir(path, vbNormal)
While file <> ""
If (Right(UCase(file), 7) = ".SLDDRW") Then
Set Part = swApp.OpenDoc6(path + file, 3, 0, "", longstatus, longwarnings)
Part.ViewZoomtofit2
longstatus = Part.SaveAs(path + Replace(file, "SLDDRW", "DRW"))
file = dir
Wend
dim path as String
Dim file As String
path =InputBox("Message","Title", "C:\Documents and Settings\BakerRob.PTT_LAN\My Documents\MGQ\")
While file <> ""
Part.ViewZoomtofit2
Part.Close
file = dir
Wend
Message was edited by: Jacob Cordingley remove extra space in part .close
The form cut off the code
here it is
swApp.SetUserPreferenceIntegerValue swDxfOutputNoScale, 1
swApp.SetUserPreferenceDoubleValue swDxfOutputScaleFactor, 1
swApp.SetUserPreferenceIntegerValue swDxfVersion,swDxfFormat_e.*
swDxfFormat_R12
swDxfFormat_R13
swDxfFormat_R14
swDxfFormat_R2000
swDxfFormat_R2004
swDxfFormat_R2007
If you want to avoid driving your users mad, I would remember to toggle system/user preferences back to their original states at the end of your code. Below is an example in C# (go here if you want VB... http://www.developerfusion.com/tools/convert/csharp-to-vb/). This doesn't refer to your settings in particular but I would probably handle it in a somewhat similar fashion. The main point is to make a decent effort to restore original settings (good practice).
private void EditUserPreferencesExample()
bool bInputDimValOnCreate = _swApp.GetUserPreferenceToggle((int)swUserPreferenceToggle_e.swInputDimValOnCreate);
try
_swApp.SetUserPreferenceToggle((int)swUserPreferenceToggle_e.swInputDimValOnCreate, false);
finally
_swApp.SetUserPreferenceToggle((int)swUserPreferenceToggle_e.swInputDimValOnCreate, bInputDimValOnCreate);
try
finally
