I am trying to bulk check in some SolidWorks drawings using the VaultAdmin tool but the check in keeps failing. See below example log file output:
>> Checking In File 'EU009.SLDDRW', Revision 'A', Status 'Approved', Number '', Description '', Project 'EU Drawings', Path 'C:\SolidWorks WIP\EU\EU009.SLDDRW'
ERROR: Failed on check in of document "EU009.SLDDRW".
Check In aborted!
ERROR: Unknown error checking in 'EU009.SLDDRW'.
As you can see the log file is not particularly helpful when it comes to working out the problem...
I can still check in files through SolidWorks and the SolidWorks Explorer.
I have recently bulk checked in other similar files in exactly the same way and that worked fine. Has this happened to anyone else?
Many thanks,
Jack
Check In aborted!
Many thanks,
Jack
