RSRich Schneider09/07/2009
I'm reasonably sure I'm missing something simple (hopefully!). When checking through an assembly, I often try to zoom up on close fitting parts to check for interferences. However, the curves obviously start getting a jagged appearance and it becomes difficult to see if one part (say a dowel pin) is smaller than the hole it fits in. Is there a simple SW command to force the curves to regenerate for smaller increments?
I've tried fiddling with the Display/Performance slide bars in the Options menu with little (if any) success, especially in an assembly file. The AutoCAD equivalent command was to just change the "VIEWRES" to a higher number and/or just type "regen" to regenerate the display. I know under Performance you can have curvature generation to "Only on demand", but how do I specifically "demand" it?
