how to set up Multi fluid analysis in flow works, i mean to
say the way we set up project in flow right that way, i need to
know the procedure. Thanks............
hi,guy,it seems simple,first creat multi fluid in fluid choose section,and then give the sub fluid domian,note the default fluid selection in wizard-->fluid ,not clear you sim object,I usually use this to sim avionic liquid cooling system.
How defining the multi fluid analysis, you can check the SolidWorks flow simulation online tutorial having examples as heat exchanger efficiency problem.Once go through that, you can easily understand the problem.
