I'm having a lot of trouble with flat layouts on SW 2009
which I never had with 2008.
When I bring my flat layout into the drawing, most of the time the bend lines either show up but cannot be picked for dimensioning, or they do not show up at all.
Deleting the drawing and doing it over appeared to correct the problem, but even then the bend lines will often disappear all on their own.
Any ideas as to what is going on here?
Did you remove the old driver and reboot before installing the latest SW certified driver?
Did you do an update of SW08 to SW09 or did you do a clean uninstall then re-install?
I downloaded Service Pack 4 and that seems to have solved the problem.
updgraded to sp 4 yesterday
