SW09 sp1 on vault. Two systems on SP3.0 (95% users) other
systems are 5% users which are network lic. are using sp1.0. A user
running 09 sp1.0 same version of the vault wants move a file from
one project folder to another project folder. He has ownership of
all the files. Goes thru the process and gets a message saying;
error you do not have write access to this project. Please try
another project or press cancel. Since than I have logged into his
system as administrator and tried with same error. I have also
tried on my system getting the same error. I have checked
permissions and he has read write access to all the projects. I
also backup the vault, and stopped and restarted the vault to
validate vault at start up with the same results as before. I have
been in contact with our Var and know solutions. Under globel
settings the following are checked: Keep extra copy of latest
files, Allow users tyo create sub projects, allow attachments to
documents owned by others to use, Allow users to remane documents
in the vault and bind ownership to Solidworks read-write/read only
access.
Any thoughts?
Any thoughts?
The range of issues that can present themselves while running inconsistent SP's vary but are significant enough to cause such problems.
