Greetings,
This is my first post, so please be patient as I may not have developed the savvy descriptive ways most users on here do, but I will do my best to describe my problem.
Has anyone ever had this problem with Photoworks? I have parts that have materials applied in Photoworks, which are used in various sub assemblies, which when placed in top-level assemblies and rendered, their materials do not render in the image, and appear to be over-ridden with the default material.
The only fix I have come across is to open the sub-assembly, and then the part(s) within it, then go back to the top-level assembly which subsequently will render properly.
All parts and materials reside locally, not over a network. The only portion of the file that does reside over a network would be the part and assembly templates.
Any tips, suggestions or guidance will be very much appreciated.
Kyle
Kyle
If you've done that and are still seeing unpredictable results, maybe check your options within PhotoWorks and make sure you've got "display PhotoWorks properties in SolidWorks" checked, with "display SolidWorks properties in PhotoWorks" (or whatever it is) unchecked.
