I have design analysis that requires me to measure the volume
flow through 70 different channels. Does it make more sense to set
all of these as goals before the run or measure them after the run?
I am concerned that 70 goals could put my solve time through the
roof or that somehow measuring afterwards won't be as accurate.
Does anyone have experience with this and which direction they
found more satisfactory?
Ken
Ken
Goals typically reduce the overall number of iterations needed to reach "convergence"; the program's built in default convergence criteria is when the calculation reaches 4 travels, which can be overkill, if you have no goals defined.
