ABAlexander Bulger03/03/2021
Hello all,
The problem I am experiencing is this: if I go to the configurations tab, add a new configuration, double click it to make it the active configuration, add a new color or dimension or feature, and then go back to the configuration and select the non modified config, all the changes are applied to it as well. I make sure the select "this configuration" option if I can OR if I use the design table it seems to take the last value entry of the column and apply it to every config available. It is very frustrating. With previous versions on SolidWorks I have not had this issue. I have SolidWorks 2020 SP5 connected to PDM Build number: 28.5 (B80). Please let me know if you need any additional information.
