In Solidworks I recorded a macro to change all the sheet formats in our drawings but it seems to stick to to the pre-defined drawing scale in the template the macro references. I'd like the macro to get the current scale of the drawing sheets on each tab it changes and use that "current" scale. Below is my current macro. I've tried searching but I'm not really sure what I should be looking for macro wise to do this. Thanks in advance!
Dim boolstatus As Boolean
Dim myModelView As SldWorks.View
Dim swSheetNames As Variant
Dim sheetName As String
Set swModel = swApp.ActiveDoc
Set swDraw = swApp.ActiveDoc
swSheetNames = swDraw.GetSheetNames
For n = 0 To UBound(swSheetNames)
sheetName = swSheetNames(n)
swDraw.ActivateSheet sheetName
boolstatus = swModel.SetupSheet5(sheetName, 12, 12, 1, 20, False, "U:\DESIGN\SOLIDWORKS\SW TEMPLATES SHEET FORMATS\CTF SHEET FORMAT_D.slddrt", 0.42, 0.297, "Default", True)
Next n
