I have a macro that saves a drawing sheet to a specific directory, inserting a custom property into the filename. Its also supposed to take the sheet name and insert into the filename, but it inserts "Sheet1" regardless of the sheet name. I have seen macros here that seem to come close to what I want, but I cant find the right code thats error free.
Can someone help me get the sheet name in the filename?
Option Compare Text
Dim fso As Scripting.FileSystemObject
Dim vSheetName As Variant
Dim Value As String
Dim DWGName As String
Dim Answer As String
Dim MyNote As String
Dim Fileprop As String
Dim Filepath As String
Dim FileName As String
Set swModel = swApp.ActiveDoc
Filepath = "H:\SHARED FILES\~DWG LIBRARY"
Filepath = Filepath + "\"
Fileprop = swModel.CustomInfo("WORK ORDER NO")
FileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
FileName = Left(FileName, InStrRev(FileName, ".") - 1)
vSheetName = swModel.GetSheetNames
Set fso = New Scripting.FileSystemObject
DWGName = Filepath + FileName + " " + vSheetName(i) + " - " + "(" + Fileprop + ")" + ".DWG"
If fso.FileExists(DWGName) Then
MyNote = "This file already exists." & _
"Would you like to overwrite?"
Answer = MsgBox(MyNote, vbQuestion + vbYesNo + vbDefaultButton2)
If Answer = vbNo Then
'Code for No button Press
MsgBox ("Complete")
Else
'Code for Yes button Press
MsgBox ("BE SURE TO ROLL A REVISION")
swModel.SaveAs (Filepath + FileName + " " + vSheetName(i) + " - " + "(" + Fileprop + ")" + ".DWG")
Else
MsgBox ("Complete")
Okay, back up your existing macro and paste the below in.
Option Explicit
Dim swSheet As SldWorks.Sheet
'Dim fso As Scripting.FileSystemObject
Dim i As Long
Dim bRet As Boolean
Dim Value As String
Set swDraw = swModel
Set swSheet = swDraw.GetCurrentSheet
'Set the DXF export option to export active sheet only
swApp.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDxfMultiSheetOption, swDxfMultisheet_e.swDxfActiveSheetOnly
Filepath = "H:\SHARED FILES\~DWG LIBRARY\"
'Filepath = "C:\Data\"
'vSheetName = swModel.GetSheetNames
vSheetName = swSheet.GetName
' For i = 0 To UBound(vSheetName)
bRet = swModel.ActivateSheet(vSheetName)
DWGName = Filepath + FileName + " " + vSheetName + " - " + "(" + Fileprop + ")" + ".DWG"
bRet = swModel.SaveAs(Filepath + FileName + " " + vSheetName + " - " + "(" + Fileprop + ")" + ".DWG")
'Next i
MsgBox ("COMPLETE")
