The hole callout for multiple drawings I am creating have incorrect depths. One shows 'THRU' when it is not, and the other shows a depth of 6.5mm when it is actually thru (an 8.5mm part). Both of these features are revolved cuts, could that be where the issue is coming from?
I have tried to manually change the dimensions but that does not work.
Any insights would be greatly appreciated.
First insight: Other than plain drill/tap holes, standard counterbores, or standard countersinks, dimension your holes in a section view rather than plan view. This has nothing to do with SW.
Second insight: Hole wizard holes that cut all the way through but are defined as blind will show up blind in their callout.
If you attach SolidWorks files instead of PDFs we can probably have more insights.
