I have an issue with my SW2020 SP2.0 regarding the scale sketch after first dimension.
It is always unchecked after I open another part or assembly.
Is anyboday having this situation?
Thank you all!
Thank you all!
My first thought is to start a new part, change the system option to "scale sketch," close the part, close SolidWorks, re-start SolidWorks, start a new part - see if it still happens. (I am also not above a full system restart.)
Changes to the system options are written to the registry when SolidWorks is closed normally - if you have a crash, it will not update the registry. Likewise, if you are still in a session of SolidWorks, it should still have the same behavior as when you originally started - because the changes have not been written to the registry.
I could be wrong, but this is what I would attempt . . .
t
I don't believe I've ever run into that, and don't remember anyone else reporting it. I've seen one or two other System Options change settings without user input, but not that one.
