The model can be downloaded here: 7191S Cylinder Head - Ricardo Version Rev (D).SLDPRT - Google Drive
I used a surface loft to model a flathead engine combustion chamber. If you look at sketch 1, you'll see a representation of the cylinder block top surface.
A surface extrude, a couple of trims and fillets are used to provide clearance for the valves when they open. All of that is good.
You'll see that I used the knit feature but it didn't seem to result in a single surface. I say that based on what happens when editing the appearance (color).
I used the edit appearance feature to change the color from grey to red. To do that I had to select the loft and the faces that make up the fillets. I was thinking that if the combustion chamber was represented as a single surface, I would only need to make a single selection.
Questions:
Does the model consist of a single surface?
If not, is it possible to make it a single surface?
William,.since you knitted it... in the folder it is seen as a single surface made up of 9 faces (images)
..if,.. you are asking if you can make this with as a single single with a single a single face...maybe?
