HI All,
Does anybody know, if you can set the global variables of an assembly by using a driveworks user's form? I have this assembly with a lot of equations to set instances and change part dimensions. It contains maybe 70 equations and only 10 are used by the engineers to configure the assembly. I would really like a 'clean' way for them to set te variables using a user's form, with drop down lists and checkboxes. I could do it with the configuration publisher, but that would create extra configurations and my company will not use configurations. We will use 'copy tree' to copy the assembly and custom parts and then set the global variables. Or is there a way to keep the configuration publisher from creating extra config?
