while using Insert part command in Solidworks Part Environment , I am not the origin in intersection of 3 planes . How to reslove this. below is the snap :-
Hi.. john.
I am not using assembly environment. I am using insert part command in part environment . So Mates will not come in to picture.
OK. Didn't notice that. What you will need to do is when placing the part make sure that you have the Locate part with MOVE/COPY toggled on. Also make sure that you toggle the PLANES on in the Transfer area and also within the part you want to insert the new part into. Then you can pick the planes & add the appropriate mates within the part. I would think that SW would default to placing the inserted part into the same origin as the new part you're trying to create but it doesn't feel that's important enough.
You will need to add mates from the part planes to the assembly planes or origin or mate the origin of the part to the origin of the assembly.
