why does "file>make drawing from part" set scale to 1:2 regardless of the template I select?
And, how can I make it respect the scale I set in the template?
Did you set the scale in the drawing template file (.drwdot)? This is going to be the one that controls the scale of the sheet when you create the new drawing.
Alex - yes I did, and to my surprize it does not have the effect you describe (which is what I thought it would do.)
I even made an entirely new .drwdot file, to be sure it was coming from the correct template directory and so forth, and still get the same pattern of behavoir.
This only seems to happen with "make drawing from file" - if I open a drawing independently and then import the file views manually, I do not see this.
De-select this option.
