Hi all,
In the attached file, I'm looking to use "SKETCH Axis" as the direction, and "Seed" as the feature, to create a circular pattern (360deg, 45 iterations, although I'm having the same issue with different values for both). When I try, SW gives me an error saying that "Geometry pattern results in disjoint bodies".
Anyone have any ideas?
Thanks in advance !
Use the Bodies instead of FeaturesAndFaces. You may have to select the body from the SolidBodies folder at the top of the FeatureManager. Alternately, you can probably use the Select Other option from the right mouse button menu to select the body from the graphics window.
