Hi all,
So in the attached file, I'm trying to create a Revolved Boss/Base using "SKETCH Rev Content" & "SKETCH Rev Axis". However, I get an error when I try to do so, and I'm thinking it's probably because "SKETCH Rev Content" doesn't appear to be showing up as a closed contour. Does anybody have any idea as to why it's not? It certainly appears to be a single closed shape...
Any help is appreciated!
Thanks in advance ,
I've run into some bad behavior with this command, but found that if I start the Revolved Boss/Base command, then select the vertical axis (construction line), then select between the three sketch segments to select the contour, the command executes as expected. If I select in other sequences, the command does not behave, even if I select the same items.
