Imported bodies may be arranged in the Part as one Face per facet/polygon.
Parts may then have thousands of faces. When imported bodies have thousands
of faces The Body2.GetFaces() function can take many minutes.
Additionally Body2.GetFirstFace() and Face2.GetNextFace() suffers similarly.
This code can take 10 minutes per body. An unexpected and prohibitive amount of time.
object[] faces = body.GetFaces();
foreach (Face2 f in faces) {
I would like to access tessellation data per face.
Can this performance issue be addressed somehow?
Tessellation objects require passing a face in to get the facets, is there a way to get full body tessellation without getting the faces first?
Please see:
SOLIDWORKS Stand-Alone API: do not compromise on performance
I'm pretty over my head on this, but my guess would be that using the separate thread is causing your API calls to be out-of-process. Artem Taturevich may be able to shed a spotlight vs. my dim candle.
