There are several issues with this file:
[EDIT 2/15/21] Number one has been solved thanks to Josh Helman. I made the mistake of asking two questions in one post, so now we've got one more to go.....
1)
Do you see this when you open cutlist properties?
Whaaa.........??? Where did my custom properties go?
2)
What happened to my sheet metal properties?
One part shows only this. Note that there is no sheet metal thickness, bend allowance, bounding box dimensions, or bends shown.
Another one, totally fine. (The custom property labels are still messed up, see #1 above).
Disclaimer, this is not my modelling. I know it's not all kosher...
Hey Michael, I'm not sure what causes this but I just saw this the other day too. You just need to double click on the line in my image below. For some reason the column was given 0 width. After you double click this line you should see another column show up, then you click ok and re-open your custom properties and now you should see your full column.
