I'm not sure what's the best workflow to design a shell and then split it into separate parts.
I think this is better than trying to design the single parts and try to make them match.
The parts could be of different materials.
Thank you!
Thank you!
Ok, should I start with a filled body and then empty the parts or should I create the cavity and then split the parts?
That's really up to you, I have seen parts be modeled in both ways. I think I prefer in most cases to model it as a solid to get the outer geometry that I want and then split the part along whichever seam you may want. Then to use the shell command to give each side a wall thickness. Lastly you can then ad any internal geometry you might want like adding ribs or fastener supports and so on.
For a better understanding on some mold design points I would recommend following the built in tutorials from SOLIDWORKS on mold design. This would give you a good understanding of some of the surfacing and mold techniques and considerations.
Help Icon > Tutorials > Advanced Techniques > Mold Design
You can do this in a single part, design the entire product and then split the bodies, you could just use cut with surface for this if you want. This is essentially mold design.
