I took over an old assembly with most likely a lot of errors.
One problem I have is a neccessary Part (that is shown while opening assembly) disappears when assembly is fully openend.
It also is not shown in the parts tree or I can't find it in the hidden objects. What bugs me is, that it is shown when opening the assembly.
Example:
Assembly consists of:
- Part1
- Part2
- Part3
While opening the Assembly all parts are shown: 1, 2 and 3. When the assembly finished loading, part2 is not shown anymore and also missing in the tree:
Assembly seems to consists of:
- Part1
- Part3
Where could I try to find the missing part?
Best regards,
Andrew
i would check the assembly reference in the data menu, so you can check the path
-> search references
in the most assemblies, i repaired, the file path is changed or the file is deleted by someone
