for tiny fillets, centerlines seem to be just creating more confusion and overcrowding an, already tight, area that includes essential dimensions.
Manually inserting centerlines in a SW drawing is the only way to go (at least up to SW 2018, as far as I know so far).
The auto insert centerline function inside Solidworks drawings has been broken for as long as I can remember, and as far as I know, there is no push at all to fix it.
So, we are stuck with the manual insert......but that's ok, since that is the way I did it with literally every other CAD package that I have worked with.
If you're using the setting that automatically inserts centerlines at all possible locations in a drawing view, I'd suggest you stop doing that. To answer the question in the discussion title, no, they shouldn't be.
