I found a macro on CodeStack that would batch check in all checked out files in a specified Vault. I have modified it to only add the files to the list if it is the current logged in user. Unfortunately it fails with a "parameter is incorrect" error at the "batchUnlockUtil.AddSelection(vault, selItems)" line. I have tried working with my VAR but they have not had any luck figuring out the issue. I am hoping one of you API gurus can help me fix this issue. The code I am using is attached.
EdmSelItem requires the document id and the project (folder) id.
