ESEric Snyder09/02/2021
I have a simple roller that needs a press fit bearing.
I have specified the diameter of the center hole in the sketch as a 17mm hole with Fit tolerance of F7 Press fit.
Using the dimension controller:
The tolerances do not automatically show up in the drawing dimension when either using AutoDimension or manual Dimension. What I am trying to do is assign the tolerances when I create the model and have a draft person create the drawings without manual intervention. Have the tolerances driven from the model automatically.
I also tried the same concept but used the hole wizard to create the hole and set the tolerances. Same result.
How?
