Hi All,
I sometimes have to model large pins and subsequent holes for these pins. These pins can be around 75 or 100 mm in diameter as well and with close tolerances. I use the hole wizard for screws and bolts. But for these large diameter pins, what is a good practice to model these large pin diameter (along with tolerances)?
LS
Not sure about good practice, but I'd probably use a legacy hole simple, then manually put in your diameter and length/end condition. Looks like dowel holes end at 25mm and it can be messy changing default values.
This means you can still define tolerances within the hole wizard feature.
Thanks, Kyle
