How to make a thread for 1/4 -18 NPT in solid works . I am not getting this thread in solid works hole wizard.
Thanks.. Kevin..
But i want 1/4-18 NPT threaded hole . Now i am getting 1/4 NPT , but i require 1/4-18 NPT thread hole.
Can you please suggest..
Debananda Shrma,Sahu wrote:
Thanks.. Kevin..
https://www.gewinde-normen.de/en/npt-pipe-thread.html
1/4 NPT is 1/4-18 specifically.
Use Hole Wizard and with ANSI Inch selected, select the Taper Tap for the hole type:
The hole will be added, but the threads are not modeled:
The Thread command models threads, but not NPT.
For modeled NPT threads, download an NPT pipe from McMaster and use Combine/Subtraction.
Kevin
