the idea is generate something like this, were the ports, (holes)., are drawn into the cilinder
i already made the transfers, and look something like this.,
but when i extrude the cilinder diameter.
here is the result
how can make the holes into the cilinder?
also here is the archive .sldprt , if u wanna take a look,.
just edit the cylinder in the context of the assembly. Make a new 3D sketch and convert the edges form the port. Then make a extruded cut (you'll need a direction vektor because it's an 3D sketch).
