the macro that I want to write takes a value out of a property from the Fileproperties and writes the value into the cutting list attribute.
The property is Teilenummer, the value of this property is taken into the code.
The attribute in the cutting list is also Teilenummer (it does already exist, see screenshot), and there I want to write the value.
The code makes a welded part and then updates the cutting list folder.
And then swFeat.CustomPropertyManager.Set2 is not working ?!
Screenshot of cutting list:
CODE Concept:
Option Explicit
Dim swModel As ModelDoc2
Dim swModelDocExt As ModelDocExtension
Dim swCustProp As CustomPropertyManager
Dim val As String
Dim valout As String
Dim bool As Boolean
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
' Get the custom property data
Set swCustProp = swModelDocExt.CustomPropertyManager("")
'Funktion schreibt Teilenummer-Werte in val und valout
bool = swCustProp.Get4("Teilenummer", False, val, valout)
Debug.Print "Value: " & val
Debug.Print "Evaluated value: " & valout
Debug.Print "Up-to-date data: " & bool
MsgBox "Der Wert/Textaudruck der Zeile in den Eigenschften ist: " & val & "Der evaluierte Wert ist: " & valout
'Mache Schweißteil aus Part
Dim swFeatureMgr As SldWorks.FeatureManager
Dim swFeature As SldWorks.Feature
Set swFeatureMgr = swModel.FeatureManager
Set swFeature = swFeatureMgr.InsertWeldmentFeature()
'UPDATE CUTTING LIST BEGIN
Dim vComps As Variant
Dim swFeat As SldWorks.Feature
Set swFeat = swModel.FirstFeature
Dim swBodyFolder As SldWorks.BodyFolder
'Set swBodyFolder = swFeat.GetSpecificFeature2
'Lese swFeat aus , swFeat entspricht erstem Ordner im Feature Baum
Dim Auslesen As String
Auslesen = swFeat.GetTypeName
MsgBox Auslesen
' Auslesen sagt Favorit Folder
' gehe Folder im Feauter Baum durch bis Cutlist Folder kommt
Dim Counter As Integer
Counter = 0
' 10. Zeile im FeatureManager Tree ist hier die Zuschnitssliste
Do While Counter < 10
'Get Next Feature
Set swFeat = swFeat.GetNextFeature
'MsgBox Auslesen
Counter = Counter + 1
Loop
swBodyFolder.UpdateCutList
'UPDATE CUTTING LIST END
'Aktualiesere Partdatei
Dim boolstatus As Boolean
Dim topOnly As Boolean
topOnly = True
'Next Teilenummer in Zuschnittsliste BEGINN
'Next Teilenummer in Zuschnittsliste ENDE
'bool = swFeat.AddCustomProperty("Teilenummer", "30", "Verify1")
Dim x2 As Integer
x2 = 222
Debug.Print "x2 VORHER: " & x2
x2 = swFeat.CustomPropertyManager.Set2("Teilenummer", 222)
Dim CustomPropertiesAuslesen1 As String
CustomPropertiesAuslesen1 = "Anfangs"
Debug.Print "CustomPropertiesAuslesen1 " & CustomPropertiesAuslesen1
CustomPropertiesAuslesen1 = swFeat.CustomPropertyManager.IGetNames(9)
Debug.Print "x2 Nachher: : " & x2
' 1 = Custom property does not exist
'http://help.solidworks.com/2020/english/api/swconst/SOLIDWORKS.Interop.swconst~SOLIDWORKS.Interop.swconst.swCustomInfoSetResult_e.html
You count until ten, then that feature is the solid body folder? That's a strange, hard-coded way of doing it. There is always one solid body folder and its type name is SolidBodyFolder.
It looks like you're trying to add custom properties to the solid body folder, that's not possible. That folder contains Cut List Folders as sub-features. You can only use custom properties on those cut list folders.
