Hi, when I import a picture using Sketch Picture, how do I tell SW to set the scale of 1 pixel in the picture = x mm of the model? What is the default value?
Hi Peter..
I believe it's exactly what you'd expect. If you can get your image the exact size you need in whatever image software you are using then it will be perfect.
If you are not so lucky then you can rescale inside solidworks.
The help file can show you easy enough. I have a slightly embarrassing video on scaling sketch pictures I made for internal use, but you're welcome to look.
pdf attached
