How do I mirror this part?
Recall trying it some time ago, was unsuccessful then as well.
Would appreciate some tutoring here.
Which is your mirror plane?
See this video for a couple methods. Works fine o n you part.
SOLIDWORKS Quick Tip - How to Mirror Parts - YouTube
There are two equally good and quick ways to mirror a part.
1) Choose a flat planar surface that is on the part or assembly and use the mirror command in Features.
2) Create a mirror plane (or use the Front/Right/Top planes) and again use the mirror command in Features.
Thanks for creating it. Looking forward for the solution.
My Balance Now
I'm assuming about Plane3, use the bodies option when selecting and since there's a gap off Plane3, be sure to uncheck "merge solids".
Kevin
