Hello All,
I have a TV and I need to mount it using a custom designed bracket. Basically, I need to find whether the TV will tilt or fall over on its own weight forward. Attached is a pic explaining how they are mounted. Basically it is a rear view. What is the difference between contact set and component contact? I have also added 170 Newstons as the force acting on the 2 of mouning points of the brackets.
Kindly, share your inputs.
School Project?
